92 Firebird Gauges into an 82 Firebird
Old Feb 7, 2011 | 12:33 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Ok... I'm sure this has been done before but I'm having little luck finding technical info on it. I thought it really wouldn't be this hard too. I have an 82 Firebird that I am wanting to get rid of the gauges in. I bought a 92 Firebird ster to take it's place. So, I put it in and EVENTUALLY got the lights to light up. I say eventually because I'm also going with LED's and it was a pain to get the lights all turned to where they'd come on. Anyways, none of the gauges work. I've searched for a pinout and cannot seem to locate one for each. I'd like to see if anyone has a pinout for the 82 and the 92 so I can repin this to make it work? Also, if anyone has done this I'd appreciate any advise you can give.
Old Feb 7, 2011 | 03:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 Firebird Gauges into an 82 Firebird
The one place you'll have issues is the speedo - 1992 is electronic and 1982 is cable driven. Not sure if it's a simple matter of swapping out the electronic unit on the tranny tailshaft and running the wiring, or if you'll have to incorporate a VSS box somehow.
Or wait - maybe all the 'bird stuff is electronic - on the Camaro there were dial guages and thus the difference - some Berlinetta's and 'Birds had digital stuff - so I dont know.
Old Feb 7, 2011 | 05:51 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Yeah, I've done the research and it appears that I'm going to need to replace the VSS in the tranny with an electric one then run a wire to the buffer box and do some wiring from the buffer to the speedometer. That much seems to match what I'm experiencing. What I handn't counted on was the panel itself not matching up. First, the lights didn't want to come on (leds) which turned out just to be me needing to twist them 180 degrees, then when they came on the whole thing was "goofy". Finally got some of that figured out. But what really is baffling me are the gauges. NONE of them are reading anywhere near accurate. I can attribute some of it to the fact that the gauges are in different locations between the two clusters. So, that would make sense in retrospect I guess. So, I'm thinking I'm going to need to repin the C1 and C2 connections to match the new 92 Firebird unit. I'm guessing I'll at least need the gauge pinout for the 92 but it would make it easier if I had the one for the 82 also just so I can see if there is anything else I may be missing (extra ground, wiring, etc.) and rule that out. All info I have on both cars is as follows.
My car 82 Firebird with a 350 and an auto transmission
Car Cluster came from 92 Firebird with 350 and auto transmission.
I'm guessing the printed circuit on the new cluster is ok, however I'm thinking I may have ruined my old one (82 gauges) in the process of pulling it out and putting it back in. These things get a bit brittle with age it seems.
Old Feb 7, 2011 | 09:59 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
http://www.hioutput.com/tech/circuits/86pinouts.html
Well, I found the one for the 86-92.... I'm guessing it's correct. Now I need one for the 82 Firebird to be able to compare it.
Wiring pinouts for 86-92 Firebird electronic dash cluster
upper
1 park brake
2 ground
3 dash lights
4 N/U
5 N/U
6 N/U
7 left turn
8 high beam
9 right turn
10 fuel gauge
11 (left spot beside voltage gauge)
12 (jumper to 12V from lower connector)
13 SES
14 shift wire -
upper
1 tan/white
2 black
3 grey
4 -
5 -
6 -
7 light blue
8 green
9 dark blue
10 pink
11 -
12 -
13 dark brown/white
14 tan/black
lower
1 tach
2 ground
3 dash lights
4 choke
5 temp gauge
6 (left spot beside temp gauge)
7 N/U
8 oil gauge
9 12V switched power (key-on)
10 N/U
11 (right spot beside fuel gauge)
12 ground
13 seatbelt
14 speedo gauge wire -
lower
1 white
2 black
3 grey
4 grey (?)
5 dark green
6 dark green/white
7 -
8 tan
9 pink/black
10 -
11 -
12 black
13 yellow
14 light green/black
Old Feb 8, 2011 | 04:04 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
old
c1 upper
14 ground 13 buffer 12 11 ground 10 illum 9 fuel 8 Temp
1 ignition to buffer 2 left turn 3 right turn 4 5 6 ignition 7 SES
c2 lower
14 tach 13 12 seat belt 11 oil 10 ground 9 8
1 high beam 2 3 4 ground 5 choke 6 brake 7
new
LIGHT BLUE top GREY BLACK TAN / WHITE
14 LEFT 13 12 11 10 ILLIM 9 GROUND 8 BRAKE
1 high beam 2 RIGHT 3 FUEL 4 5 6 SES 7 UPSHIFT
green dk blue pink dB / wh tan/black
LT GREEN/BLK YELLOW BLACK bottom PIN/BLACK TAN
14 VSS 13 seatbelt 12 ground 11 10 9 ignition 8 OIL
1 TACH 2 GROUND 3 4 CHOKE 5 TEMP 6 7
WHITE BLACK GRAY GRAY DARK GREEN DK GREEN / WH
Old Feb 9, 2011 | 07:47 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Does anyone know HOW to remove these PINS?? Preferably without breaking them...
Old Feb 13, 2011 | 01:07 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Ok, I found out about a great little tool to remove the pins in the swap.... A plain old ordinary hair pin..... Came across the idea from someone else and sure enough, works better than anything else I was trying... Cheep tool too.
Old Feb 13, 2011 | 01:08 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Oh.... Does anyone have the pinouts for the color codes that correspond to the 82 Dash Gauge Cluster? I'm needing them to fix this mess.... Evidently I'm getting something totally screwed up and cannot figure it out..
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
justin57
Aug 20, 2015 07:05 PM
ChevyZ71
Aug 13, 2015 07:30 AM
