fuel pump wires
Old Feb 21, 2011 | 09:59 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
fuel pump wires
86 firebird w 2.8/the wires running into the tank after they come throught the car body.There are 3/1red 1/black 1 gray.or so that is what they looked like.for me to try to see if this pump is good and not a wireing problem I want to run power into the pump as close to it as I can.I looked at wireing diagrams and they don't even have these colors on them.not the gray one and I see orange insted of red.do I conect the red battery to the red wire going to the pump and the black battery to the black wire going to the pump and figure the gray gose to the fuel gauge?Anyone know about this.Also is this safe to do this close to the tank?
Old Feb 22, 2011 | 04:20 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: fuel pump wires
I can't member but I know that the dead obvious one that looks like it should be the hot is the fuel gauge, as I just did the movie bomb trick when doing mine n just guessed n cut the most likely wire
Which would mean the red or pink one is more then likely the fuel gauge [the ones Id guess to cut first], black will be ground always, which must mean the gray is it but it is 5am here so mull it over before you cut.........
Old Feb 22, 2011 | 07:33 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: fuel pump wires
ok,try after work
Old Feb 23, 2011 | 06:39 PM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel pump wires
Add 12v to the gry while grounding the blk
Old Feb 24, 2011 | 09:53 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: fuel pump wires
thanks,soon as the weather get better I will slip up under her and make her hot on the gray and ground the black.
Old Feb 26, 2011 | 11:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: fuel pump wires
put a wire from pos.battery to gray on pigtail.put neg.battery to black on pigtail.small sparks but no run!dead pump!
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
