not to big on electrical.. fan problem
Old Feb 22, 2011 | 06:22 PM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
on my 88 formula my fan doesnt seem to come on it doesnt come on after it warms up or anything and its connector is all the way in. whats going on? someone care to help? thanks
Old Feb 22, 2011 | 06:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: not to big on electrical.. fan problem
Pass side head, between #6 & #8 spark plug, there is a sensor looking thing - it's the fan switch - probably a bad one. To test, remove connector (squeeze it at the ridges to remove) and stick a wire into it and ground that wire anywhere metal on the car with the key turned to ON - if the fan runs, the switch is bad. Cover face when replace, will get a face full of coolant there.
If fan still doesn't run, then bad relay - it's on firewall driver side between brake booster and fender - there's a square holder mounted to firewall with two 10mm bolts - 2 relays inside that 'holder' - one is fuel pump, other is fan. The fan relay has a large black with red stripe wire to it. Usually the fuel pump relay is the same as the fan relay, if both are oval shaped, then mark the fuel puimp relay (the good one) and switch them - then ground that fan switch wire discussed above and see if the fan runs. If it doers, get new relay.
If all that fails, apply 12v directly from battery to the fan wire at the connector (with a ground of course) and see if the fan runs - if it does go back to above and retry, if it doesn't, replace fan motor.
Old Feb 24, 2011 | 11:44 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Another easy way to test is by moving the top slider on the HVAC control over to AC. If the fan goes on then the fan and relay are OK and replacing the switch that Newbie referred to should do it
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Aug 6, 2015 04:15 AM
