delete convenience center?
Old Feb 22, 2011 | 08:18 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Is it possible to delete the convenience center entirely? I believe the one is for hazards which i don't need, then something that is a box shape for an alarm sound? I want to keep turn signals, but that flasher isn't located in there, so can I just remove it entirely? fuel pump, ignition, etc is all on fuses/relays separate so that's not an issue.
Old Feb 23, 2011 | 10:47 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: delete convenience center?
You can remove the buzzer with no issues. I'd keep the 4-way flashers though. It's a requirement for inspection in every state (whether they check or not), and the minute you remove it, you'll be broke down and wish you had it.
Old Feb 23, 2011 | 03:29 PM
xpndbl3's Avatar
Car: 1984 Z28
ended up rewiring the hazard flasher and just cut all the other wires off and pulled them. So that big panel is gone now.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
