4th gen headlight switch wiring issues....
Old Feb 25, 2011 | 07:34 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
got a few extra wires here, just wondering if anyone has done it before. 84 camaro, 98 camaro dash swap.
3rd gen-4th gen for headlight and dimmer switch
red-red
red-red
yellow-yellow
orange-orange
black-black(for both dimmer and headlight)
now for the ones i'm unsure of:
The thirdgen side has a green and a brown, the 4th gen dimmer has green, brown and grey. The 4th gen headlight has grey and brown.
The dimmer switch wires go in this order looking down the side of the 4th gen switch....green, grey, black, brown.
Which ones do I connect together then?
Old Mar 17, 2011 | 12:49 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: 4th gen headlight switch wiring issues....
did you get this sorted out?
Old Mar 17, 2011 | 04:28 PM
xpndbl3's Avatar
Car: 1984 Z28
i "think" so the headlight switch works fine, so does the dimmer switch. Just not sure if one of the wires that I connected together should be left disconnected on the 4th gen wiring side or if connecting them like I did is fine. Right now the off/parking light/headlight works perfectly, as does the dimmer switch.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
