87 IROC-Z 700r4 Transmission
Old Mar 7, 2011 | 02:28 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I have pulled the original wiring harness out of my 87 IROC because the system isn't capable of doing what I want it to do. I have installed a FAST ECM with dual sync distrib which is currently installed..
What I am trying to get an understand is how the transmission electronics needs to be wired.
Here is what I know.. The transmission has a top gear selector switch and a Torque convertor switch.
Do you have to use the top gear selector switch in order to use the TCC.
Which wire by color would go to where??
Old Mar 7, 2011 | 02:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 87 IROC-Z 700r4 Transmission
In the tranny section, there is a sticky at the top that discusses TC lockup with wiring diags and info on the 700R4. Yours is a tricky year, mid 1987 GM made changes inside the 700R4, so you'll need to follow that sticky and determine which tranny you have, whether you have a NO or NC switch, etc.
Old Mar 7, 2011 | 02:37 PM
Car: 1992 RS
Engine: Carbed 350
Oops - it's in the carb section, not the tranny section...
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
