Heater fan doesn't work constantly?
Old Feb 28, 2011 | 08:57 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I know there are TONS of posts on heater motors, and vents and everything else, but I haven't really seen one that matches what I'm experiencing. Close, but not the same.
The problem is that the fan doesn't work consistently. I can turn it on and off just fine. After school today, I got int h car and left school forgetting the fan was on(didn't hear it or anything) and I stopped for gas. AS I pulled out of the station, and hit the gas the fan came on. It acts almsot as if it's connected to the throttle(obviously it isn't). Could it be a sign of the motor going bad? I thought the motor was fine because it goes through the different speeds, and works as I assume it should. I also don't get very much air through the vents even on high.
Thanks guys!
Old Feb 28, 2011 | 09:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Heater fan doesn't work constantly?
Are you sure it's not working always, but maybe just only blowing out the defrost vents sometimes (indicating a vacuum leak)?
Old Feb 28, 2011 | 09:11 PM
chevydrvr's Avatar
I can hear it come on and off. I can feel it too, it's a big burst of air when it does randomly come on, then it's back to almost nothing.
Old Feb 28, 2011 | 10:04 PM
Car: 1992 RS
Engine: Carbed 350
Is it at just the high speed setting, or all of them? If just high speed, I'd check the relay and wiring for it that is attached right to the heater box. If it's only low speed settings, then I'd try replacing the resistor in the heater box housing.
Old Feb 28, 2011 | 10:31 PM
chevydrvr's Avatar
I have the fan on high all the time since there is little air coming out, Where is the relay for the heater fan?
Old Mar 1, 2011 | 08:45 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relay-ing Information
The blower relay is located at the blower housing.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Mar 1, 2011 | 04:03 PM
chevydrvr's Avatar
How do I check the relay? I just took the heater fan out and everything to check inside for any leaves and stuff and realized the fan was sealed in with some type of caulking and only one screw. That might be why I get no air flow.
Old Mar 1, 2011 | 04:27 PM
Car: 1992 RS
Engine: Carbed 350
You should hear or feel it 'click' when someone turns the fan on. Remember, the fan stays on always unless the lever is slid to OFF. You can unplug it, check the wiring connector for burns and such.
If it has markings on it (sometimes on the top), then terminal 86 should be a ground, terminal 85 should get 12v+ when the fan is turned on (high setting), terminal 30 should have 12v+ always (with key on), and terminal 87 should have 12v+ only when fan is on (high). I believe, if there is a terminal 87a, it should get 12v+ only when fan is on lower speeds (there's 3 speeds, low, med, hi - terminal 87 should only have 12v+ when set to hi, terminal 87a would have 12v+ when set to lo or med).
Old Mar 2, 2011 | 07:23 AM
NINÅ's Avatar
Transmission: 765R4
Re: Relay-ing Information
To test the relay independent of possible wiring problems from the HVAC switch, apply 12 volts to pin D orange wire.
If it’s good you will hear it ··CLICK··.
Also, if the rest of the relay and blower circuit is good, the blower will come on.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Old Mar 4, 2011 | 05:03 PM
chevydrvr's Avatar
I haven't checked the relay yet, but isn't it good because the motor does come on?
Old Mar 4, 2011 | 05:25 PM
Car: 1992 RS
Engine: Carbed 350
It's a SPDT relay. I'm not 100% sure, but I'm assuming that the relay switches power between one relay terminal and the other, so that when blower is on high, power sent directly to the blower motor, when on low or med, power sent to the resistor then to the blower motor (where the resistor lowers the voltage along the way).
So, if looking at relay diagram, for example when set on high, power runs from 30 to 87 (straight to motor), when set on med or low, power sent from 30 to 87a (which routes through resistor). Since 87a is the default (relay not activated or not working), lower speeds would still work.
Old Mar 4, 2011 | 05:31 PM
chevydrvr's Avatar
What I'm not understanding is why I can still go through all the fan speeds. If the relay was bad, wouldn't it not work on all speeds? Or, is is possible that the relay works sometimes and not others?
Old Mar 4, 2011 | 05:34 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I would just buy a new fan motor from your local chevy dealer. They are not that expensive ( if I remember right around 30 bucks) and it is common for them to go bad.
Old Mar 4, 2011 | 05:41 PM
Car: 1992 RS
Engine: Carbed 350
The relay might be fine - it was just that it's an easy part to test and a cheap part to replace (under $10). But yes they can work sometimes and not others.
Old Mar 7, 2011 | 04:20 PM
NINÅ's Avatar
Transmission: 765R4
The relay is used for high speed only.
The other speeds go thru the resistors.
You can determine if the relay is involved in your problem by turning the speed selector to medium.
If the fans cuts out when in that position you will know the problem is not relay related.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Wade787b
Sep 29, 2015 01:15 PM
lakeffect2
Aug 23, 2015 08:44 AM
Leggman1
Aug 6, 2015 04:15 AM
