windshield wiper problem
Old Mar 5, 2011 | 01:11 PM
gunstockmaro's Avatar
ok so i have a 91 rs camaro,bin trying to get it set up for the roaad and got most everything fixed sept the windshield wipers i want to thing its the switch but idk dos iny one have some tips on how to check the motor switch and everything cuz im far from an electrition so inything will help.
Old Mar 7, 2011 | 04:30 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
Open the wiper motor unit.
Apply 12 volts to the
purple wire.
If the motor is good it will run, then you can probe the wires at the steering column connector.
The connector is a flattish type with about 11 wires.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the
16 AWG WHITE wire entering the steering column to see if it has power when the key is in the RUN position.
If it does, turn the wiper switch to the HI position, then probe the
purple wire, then the gray wire.
Each should have power.
If not, see if your wiper switch is getting voltage in.
Voltage enters the switch VIA a
16 AWG white wire.
If it isn’t getting voltage in, trace it back to the fuse.
If it is getting voltage in, see if it puts out voltage when you cycle the switch.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
eddie jr
Aug 25, 2015 06:52 PM
