Looking for fuse panel plug
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
Looking for Fuse panel plugs, specifically Pico 0952 and 0951. Anyone know if these are available locally(Advance, AZ)? I have wired my new stereo and electric fans, but want a clean install into the fuse panel. Look like these.
http://www.amazon.com/Pico-0952pt-Fu.../dp/B00030CPMS
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Looking for fuse panel plug
You can use a single 1/4 inch male spade terminal, crimp it on your wire, and stick it in the empty slots on your fuse panel.
There are 4 empty slots - they are single slots (won't accept a fuse because a fuse has two tabs) ...
BAT = power always
IGN = power only when key is on
RADIO = power when radio is on
LPS = power when lights are on
BAT = power always
Engine: 5.0L HO L69
Found at local Carquest. I had the spade terminal soldered onto the wire, but accidentally knocked it out using the clutch and my cooling fans obviously stopped working. I am not ready to button up everything just yet, and needed a proper solution.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
