Removing Wiring from Options No Longer Installed in Car
Old Mar 24, 2011 | 11:48 AM
MNformula350's Avatar
I removed all my Power Options in my Formula (Weekend Cruiser, Auto-X & Road Race Car) and I want to take out all the excess left over Wiring.
I have Removed ther Factory Power Windows, Door Locks, Mirrors & Trunk Pull Down (Swapped to 82-85 "slam" Latch Best Mod Ever!)
I was going to just Carefully, Remove it all back to the Fuse Box, and was wondering if there is anything I should watch for, or keep in mind, so as not to cause electrical issues later.
Thanks!
Old Mar 24, 2011 | 11:50 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Removing Wiring from Options No Longer Installed in Car
Just terminate the ends so that no 12v+ cut wires can accidentally touch any ground sources.
Old Mar 24, 2011 | 11:59 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
grab yourself a helms manual and just double check that the circuits you're pulling don't share any power or grounds with the stuff you are keeping. otherwise take it slow, and make sure you've disconnected the battery ahead of time (should be understood already, but bears repeating )
Old Mar 24, 2011 | 12:00 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If they are removed at the fuse panel, that's it.
I'm sure you'lll disconnect the neg battery cable before you start pulling wires.
Old Mar 24, 2011 | 01:40 PM
Thanks for the tips, I do have an original Factory Service Manual as well.
I removed all this stuff back in 03, but was in a hurry to put the car back together for a Car Show. Just getting around to tidying up.
rocn7roc
Sep 21, 2021 02:16 PM
midge54
Sep 2, 2020 07:13 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
