12 volt question
Old Mar 26, 2011 | 09:48 PM
danialreed's Avatar
12 volt question
I need to run my electric choke to a 12v source that is powered by the key. Will my tach slot running to my hei distributor work?
Old Mar 27, 2011 | 03:53 PM
lordmalice76's Avatar
Car: 1991 camaro rs
Axle/Gears: stock
Re: 12 volt question
no. run it off an ignition run fuse like the radio. the tach is a signal and isn't a constant 12v.
Old Mar 27, 2011 | 04:02 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Also wrong. Do not run the choke off of the same circuit as the radio, or any other shared circuit for that matter.
Electric choke produces heat, so it needs a good, isolated 12v power supply. Run a fused wire directly from an ignition switched source on the fuse panel.
eightsixseven
Dec 16, 2024 01:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
BOOT77
Aug 10, 2015 12:20 PM
