digital cluster swap into 88 GTA
Old Apr 3, 2011 | 07:41 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Just want to dispel a myth that you need an entire chassis harness to swap a digital cluster into a non digital cluster car. You dont.
I just installed one into my 88. Didn't require anything more than depinning the cluster connectors, labeling them and cutting the old pins off. Then you solder the new connectors on via the digital cluster pinout diagram and WHAM! It works.
There are an awful lot of wires on the digital dash. Most are common grounds and power wires. The only new things needed are feeds for the L and R door open indicators, coolant level sensor, and hatch ajar (that I think of off the top of my head)...
Old Apr 4, 2011 | 01:23 AM
kcid_n_ysup69's Avatar
Car: 89 formula
Re: digital cluster swap into 88 GTA
you have any pictures? im just curious to what color the vss wire is? making a custom gauge settup similiar to the one on the very bottom of this page labeled "stock digital replacement gauges." i didnt rip the idea off the manufacturer, i had seen alot of guages for camaros and figured id try to make one for my bird w.o dishing out all that cash http://www.markscustomkits.com/Interior-Products.htm
just curious i still havnt figured out which one is the vss wire i need to connect my white speedo gauge wire to, any help is appreciated
Old Apr 4, 2011 | 03:29 AM
Car: 89 formula
nevermind i got my answer
Old Apr 4, 2011 | 06:15 AM
dhirocz's Avatar
white? your VSS feed should be LTGRN. There are two this color, one is for the turn signals.
Old Apr 4, 2011 | 10:14 AM
Car: 89 formula
i got a digital speedo, i connected my white wire from speedo to the "S" on the back of my circuit film on my cluster , the wire coming from the digital gauge was white. but i can see which wire your talking about now i beleive its 14 on the lower cluster pins. i hooked it up and the readings were everywhere. i think it just needs calibrating..hopefully
Jeremys87
Jul 14, 2022 09:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
