1992 dash into a 1984 berlinetta
Old Apr 6, 2011 | 04:34 PM
chalkstar's Avatar
Car: dodge ram & camaro berlinetta
Engine: 5.9 in ram 5.0 in camaro
Transmission: auto
hi need help
can i fit a 1992 z28 dashboard into a 1984 berlinetta as berlinetta digi dash has died
thanks
Old Apr 6, 2011 | 05:21 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 1992 dash into a 1984 berlinetta
Anything is possible. You'll also need the brackets from the 92, as well as the wiring. It will not be a direct swap, and it will take quite a bit of work to get right.
Old Apr 6, 2011 | 05:51 PM
chalkstar's Avatar
Transmission: auto
thanks
sounds a bit heavy is there any wiring diagrams to assist this process
thanks again
Old Apr 6, 2011 | 06:10 PM
I really dont have much knowledge of the digital dashes, or if they use different sensors on the engine and transmission or not. There are wiring diagrams on this site, you just have to look for them. What I would do is get the cluster wiring diagram for an 84 berlinetta, and the same wiring diagram for a 92 camaro, and see what the differences/similarities are between them. It will be a big job, and your best bet may just be to fix/replace your digital cluster.
MantyZ28
Nov 8, 2015 06:54 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
