Fog lights
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
Fog lights
I did a search and found a few things on the fog lights, but I did what the it said and replaced the relay because the fuse was blowing instantly. The new one worked for a minute and now I am back to blowing fuses right away. Any help would be much appreciated.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fog lights
http://www.austinthirdgen.org/index.php?pid=19
That's wiring diags - scroll down and look at the 1992 diags for foglights - that might help you - sounds like you're getting a short (ie 12v+ is grounding somewhere). There will be very little (if any) difference between the 1990 car and those 1992 wiring diags.
might be some info here that could help as well - http://www.austinthirdgen.org/index.php?pid=17
Car: 90 IROC-Z
Engine: LB9
Re: Fog lights
So fog lights have not been working and I have been working on them. I have found that with a new fuse put in and the fog light switch off, as soon as I pull the head ligh switch on it blows the fog light fuse. Any ideas?? Bad fog light switch?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Driving In London
Remove the fog light relay.
Does the fuse still blow?
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
