No Blower, Defroster, Brights, Radio, and fogs Help!
I bought a used 85 trans am with a 350 auto swap, The car obviously has some problems but the worst are that there is no heat, You can feel it seep through the dash but the blower does not work at all, The rear defroster does not work at all plus the button will always pop up, not stay down. It seems the brights are on 24/7 you cannot turn them off or on just always on brights, And the radio does not have any power at all. I checked all the fuses. I was wondering if at least the interior things have a common circuit or something that I could check Thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Heat Stroke
We don’t know what state you’re in but it’s probably cold so we’ll start with the blower.
We will assume the car has or had AC (if it never did the circuit is different).
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the blower relay pin A red wire.
It doesn’t matter what position the ignition key is in.
Is there power on the red wire?
Happy Racing!
I Didn’t Wreck, The Track Moved
Happy Racing!
Gunner242
Dec 25, 2015 04:49 PM
