TURN STEERING WHEEL = ELECTRICAL SHORT?
Old Apr 11, 2011 | 11:16 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
When I turn my steering wheel all the way right, the electricity increases (eg. lights brighter, fan blows faster etc). WTF? I know there are wires ON the colum, but what could cause this?
VATS? I swapped my steering column with one from a firebird, but I don't believe it has a VATS module? What could cause such a short?
Old Apr 12, 2011 | 05:20 AM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: TURN STEERING WHEEL = ELECTRICAL SHORT?
Is the engine running? It's possible when you stop the wheel against the end, it's causing the engine to get more load on it (due to the power steering pump trying to push against a hard stop), which would easily cause this. Also, the engine rpm could change (which would affect alternator output at idle) when you just move the wheel, again in response to the power steering pump using power.
So... does it do it with the engine off?
Old Apr 12, 2011 | 09:32 AM
Car: 1984 Z28 T-TOP
No, only when in gear.
Check this out!! It only happens in gear and also when I shift gears. I think there is a circuit connecting the switch that prevents the starting in any gear but P or N and the ignition.
Old Apr 13, 2011 | 10:25 AM
Car: 1984 Z28 T-TOP
And even more interesting; at the end of each turn (eg. fully right or left) the voltage goes up. I think I am going to have to change the column. I think there may be a short in the knuckle.
Jorlain
Aug 24, 2022 05:11 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
