No Radio Power
Old Apr 19, 2011 | 09:44 AM
my82roc's Avatar
Car: 89 Iroc Convertible
No Radio Power
Have a strange problem.Recently had my dash and interior replaced in my 89 Iroc vert.After putting back the center console I noticed my console clock wasnt working.The 2 backlights would light up when headlight switch was pulled.Since I have this spliced into the radio wiring I went to plug in the radio and with key in all positions it didnt turn on.I only got backlight illumination with headlight switch.Both parts worked before removal.I checked the radio fuse and it was good.....One thing to note,I had to extend the console clock connector plug as it was kinda tight.I wanted to have a bit of slack so I cut the pigtail off to put a longer one on.When I cut the wiring it sparked as the battery was still connected.This means that there was power...correct?But now nothing.Any help would be appreciated
Old Apr 21, 2011 | 08:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: No Radio Power
Does your radio have an inline fuse?
Old Apr 22, 2011 | 07:47 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: No Radio Power
Check all of the fuses in the interior fuse panel.
Old Apr 23, 2011 | 10:16 AM
my82roc's Avatar
Re: No Radio Power
No its a gm factory cd player.After looking thru the gm shop manual and searching the old posts I found that there is another fuse in the conveinence center labeled ARC.I havent had a chance to check it yet but I think thats my problem.
Old Apr 23, 2011 | 09:02 PM
my82roc's Avatar
Re: No Radio Power
Problem Solved......ARC Fuse was the culprit
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Aug 27, 2015 11:14 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
