Need help with wiper motor test diagram!
Old Apr 20, 2011 | 09:33 PM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
My wipers are currently not functioning except in high speed and they are not going into the park position. I am trying to test the wiper motor to see if that is the problem. The attached document describes how to test it and shows a diagram but I am not that great with electronics and am a little unsure about how to test this properly.
According to the "Lo Speed" test, I need to connect pins 2 and 3 to a 12 volt source (I am going to use the car battery). However, I am not sure what I need to do with pins 1, 7 and 8. It appears that I need to connect separate test leads from those pins to a ground source. Is that correct? Isn't the wiper motor already grounded through the bolts attaching the motor to the firewall? This is confusing. I know this is probably basic stuff but I would REALLY APPRECIATE some help on this!
File Type: pdf
Old Apr 21, 2011 | 12:42 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Need help with wiper motor test diagram!
yea, it looks like you ground pins 1 7 & 8 during the test
Old Apr 21, 2011 | 12:50 PM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
So I just connect three separate jumper wires from those pins to the engine block or other good metal contact?
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Glowsock
Jan 9, 2017 04:06 PM
Mickeyruder
Sep 2, 2015 02:45 PM
slade5612
Aug 11, 2015 07:19 PM
