Power window wiring help
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hey guys. Not many people have done what I am in the process of doing on a 3rd gen so I need to pick your brains. I have a painless 18 circuit chassis harness installed. For the power window circuit all it gives you is a fused power wire for each side. I have my complete 3rd gen power window wiring in place and have the pink power wire coming off the switches. I don't think I can attach it directly to the painless fused wire so how would I go about getting power to that pink wire for the switch?
Any way to get a relay system with both painless wires going into the single stock pink wire? I know the factory setup didn't use a relay so I'm stumped.
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: Power window wiring help
I am very intrested to see how things work out for you. I have another post up on the board asking if the painless 18 circut kit will work for our cars. I hope somebody chimes in with a answer.
Car: 1986 Trans am
Engine: 5.3 LM7
My biggest concern at the moment is what circuits I will need to use relays on, and what circuits can run right off the painless fuse block alone. I am thinking the window and door locks each need a relay but am not 100% sure which is why I asked my original question.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Any of the higher amperage applications need relays. The relay uses a low amperage activation wire to "activate" the coil inside the relay, which then literally throws a pole from one direction to another to transfer higher amperage battery power directly to the application.
But I'm no expert on window switch and power window operation, so I won't speculate on the actual wiring and post what would surely be bad wiring example.
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 92 Z28 Camaro
How is the wiring coming along? Did you get it all sorted out? I'm intrested in your progress to see if the kit is worth the money?
Car: 1986 Trans am
Engine: 5.3 LM7
I actually completely finished the chassis harness as of a few weeks ago. Came out awesome and everything works as it should. I'm very happy with painless's quality and support. If you have any questions, ask away!
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
