Dash Ground location?
Old Apr 22, 2011 | 11:31 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have an 84' Z28. Where would I look to find the dash grounds? Both on the block and behing the dash.
Old Apr 22, 2011 | 04:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dash Ground location?
In the engine bay, you have 3 main grounds
1) Battery neg cable to engine block
2) groundstrap from pass side rear head to firewall
3) small neg battery wire to fender
In the schematics, doesn't really show any single ground for the dash. The entire metal of the car is grounded from the engine bay (except a few metal parts that are isolated with plastic). So, all these dash parts - most of them have their own little grounds. I asume the actual cluster has a ground in the ribbon cable connector.
Is there a particular part of your dash (ie gauges, or lights, or cig lighter, or clock, etc) that is not working, or is it the entire dash?
Old May 23, 2011 | 04:22 PM
Car: 1984 Z28 T-TOP
Gauges. Spedo works, but temp gas and battery do not. battery is pegged bottom.
Ghettobird52
Jul 5, 2024 11:18 PM
Casey Meyers
Mar 2, 2016 10:46 AM
LittleFranks
Sep 17, 2015 12:22 PM
Pilotrick50
Sep 2, 2015 12:48 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
