fuel gauge sender (fgs) readings...
Old Apr 26, 2011 | 11:32 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can the fgs be read with a dvm or ohmmeter??
Old Apr 26, 2011 | 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel gauge sender (fgs) readings...
Yes
Old Apr 26, 2011 | 11:38 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You can test the fuel guage with a variable resistor. 97 ohms is full, 10 ohms is empty. If the guage doesn't pass this test, verify power and ground. guage failure is rare though the delay function gerally goes bad after several years. That's why our fuel gauges bob up and down with movement of the vehicle. The sending units do fail along with wiring.
Ghettobird52
Jul 5, 2024 11:18 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
