Battery problem
Old Apr 28, 2011 | 05:29 PM
Heyzus's Avatar
Car: 1987 Trans Am
Engine: 383 Stroker
Transmission: 700r4...sort of
Battery problem
Hey,
I recently pulled apart the dashboard in my car to get at the heater core. So, naturally i had to unplug the battery to work safely. Well, I was an idiot and unplugged the positive terminal first. Realized my mistake soon after and unplugged negative/put back positive. I finished putting it all back together yesterday and when i went to plug the negative back in, sparks flew and i think the headlight motors went apeshit.
Now, this is where my issue lies. I put the ground onto the positive because i was fairly sure that's where it used to be, but when i used to work on the truck, the ground was at the negative terminal. is this why it's sparking?
long story short: positive has ground, negative is unplugged. plugging back in headlights go crazy and sparks fly. please help.
Old Apr 28, 2011 | 05:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Battery problem
The car is negative-grounded.
Old Apr 28, 2011 | 10:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Battery problem
and it doesn't matter which cable you remove
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
mddaniel
Sep 8, 2015 05:16 PM
justin57
Aug 20, 2015 07:05 PM
