speedometer is reading wrong
Old Apr 30, 2011 | 06:48 PM
phlipdawg's Avatar
My 89 GTA has a 140 mph speedo that is reading approx 10 miles an hour faster than i'm actually going. i.e. says i'm doing 60 mph and i'm actually going 50 mph. Any ideas?
specs on car is it's a 89 GTA 5.7/auto
thanks for any help
Old Apr 30, 2011 | 07:19 PM
Marauder's Avatar
Car: '91 Z-28
Re: speedometer is reading wrong
Does the tire size match the size indicated on the sticker on the inside of the driver's door? I had a different tire size on a car once that caused the speedometer to be off 1mph for every 10mph I was going. Ex: If the speedometer said I was going 70mph, my actual speed was 63mph.
Old Apr 30, 2011 | 07:40 PM
phlipdawg's Avatar
yes the tire size is correct
Old May 1, 2011 | 01:56 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Has there been any drivetrain work done on the vehicle? Is the rear axle original? Has the transmission been rebuilt? There are a number of different drive and driven gear combinations available for the VSS drive. If work has been done on the trans, the wrong gear combination may have been installed. Look in the GM(Helm's) factory manual for your car to find the correct combination of gears to correct your speedo reading. If no work has been done on the car, you may have a defective VSS or circuit.
IIRC, on the 700R4 with electronic speedo, the VSS outputs an AC signal of varying strength(frequency and amplitude), which the speedo driver translates into a MPH value. A poor connection or interference in the circuit could cause a false signal. Make sure that no plug wires are laying against the main engine harness.
Ghettobird52
Jul 5, 2024 11:18 PM
toones
Jan 6, 2016 06:00 PM
AUZ28
Oct 12, 2015 08:40 AM
GTAman
Sep 21, 2015 09:57 AM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
