Power Door Lock Relays
Old May 3, 2011 | 01:17 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Mine are defective.. Finally know what the problem is! Now I need to replace mine but GM has none left (discontinued) and nobody else that I know of carries them.
I need a power door lock relay that will work with an 86 Camaro.. From what I know there are two types, 82-89 and then 90-92. I need the 82-89 version of this relay that goes under the kick panel on the driver's side.
There is one in a scrap yard but it would have to be shipped. Plus it is used and I would much rather just put in a new one.
Thanks!
Old May 3, 2011 | 09:01 PM
Bronk's Avatar
Car: 82 Camaro Z28
Transmission: auto
Re: Power Door Lock Relays
Take one out and take it down to the local accesory installer they probly have the right relay on hand. try to get a bosch if you can
Old May 4, 2011 | 08:11 PM
i dont have a local accessory installer.. I'd have to order it online.. I've been looking still and I have found 88-92 one such as this one: http://www.rickscamaros.com/camaro-p...1988-1992.html
Any ideas where to find an 86 one online?
Old May 5, 2011 | 05:24 PM
Bronk's Avatar
Car: 82 Camaro Z28
Transmission: auto
can you post a pic of the relay, if you can get the number off of it and a pic of the bottom would help ..
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
