83 Camaro, won't start
Old May 8, 2011 | 12:08 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Hi guys,I have an 83 z28 that I have recently done a Crossfire injection to Carburetor swap in. Finished a couple weeks ago and it started everytime on a dime. Recently, after throwing on a new Edelbrock 600, I went to turn the car over and it appeared that the starter had gone bad. I pulled and replaced the starter because judging by the look of the solenoid and the gear teeth, it was time for a new one. After the new starter was in, when I turn the key to the start position, it may crank a few turns but power is being surged and won't turn the starter fast enough to start the engine. I thought it was the battery so I threw in the new one from my truck and the same thing is happening. When the power surges to whatever source is draining, I still have full power to every other component in the car. A couple of days ago I went to crank it and my positive cable where it meets the battery began to smoke, as did my solenoid. Then, with the key in my hand and out of the ignition, the starter gear was still in contact with the flywheel and slowly rotating the engine. I'm thinking either a bad starter,(local shop only sells remanufactured starters) or a bad ignition switch. Would an ignition switch cause such a drain though? Any input would be very helpful.
-Chris
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
