fan problem
Old May 9, 2011 | 02:08 AM
91maroRS91's Avatar
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
fan problem
I Just bought a Hayden adjustable fan controller and its go 2 wires that I don't know Where they g. The one wire says it goes to the pos ignition and the other to the a/c clutch. Where are those wires located, does it matter that my a/c doesn't work and last the controller is setup for 2 fans but I only have 1 will it still work. Please help me out.
Old May 9, 2011 | 01:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fan problem
Just disregard the wire for the A/C - if the A/C is not working anyway. The A/C wire is to make the fan come on at all times the A/C is running because the working A/C naturally makes the car run harder (and hotter).
The other wire I presume just needs a hot-in-run connection. Should be able to just tap into almost any wire that gets 12v+ with the key ON.
Does Hayden have a wiring diag on their website for THIS controller that you can post up a link to so we can see to verify?
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
