Re. Burned up Fuse links Starter/ Alt.wires
Old May 9, 2011 | 01:05 PM
WickedTTa's Avatar
My fuse links by the starter burned up the other day and the electrical system on the car died- at the same time the right rubber brake hose gave out and the brake peddle went to the floor at a stop light. It has an old viper alarm system left over I'm pulling out just in case- any comments ? I'm checking Hawks for a replacement alternator and positive battery cable and wire.
Old May 9, 2011 | 02:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Re. Burned up Fuse links Starter/ Alt.wires
Why pay Hawks extra for a part that you have an abundant local supply of? Any Autozone/Advance/Oreilly's/NAPA/CarQuest alternator is fine. They will also have a battery cable, and just about everything else you need. And if not, they can special order it, have it in 48 hours, and a way less expense that Hawks, Jegs, Summit, etc.
gta892000
Aug 11, 2019 11:16 AM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:37 AM
Glowsock
Sep 11, 2015 11:09 PM
64goatman
Sep 9, 2015 01:09 PM
