BRAKE LIGHTS WONT STAY ON!!! HELP!!
Old May 15, 2011 | 03:10 PM
DiligentWaffles's Avatar
Car: 1983 Camaro
Engine: 2.8L V6
Transmission: manual 5-speed
my '83 brake lights only turn on when i press the brakes n i narrowed it down to the wires being grounded...maybe im just stupid but i cant get the tail lights off n i tried goin throught the trunk lik newer cars but theres no screws!... uhm yea this is the first older car ive worked on n its my first car.... pics if u can please..i really wanna be able to drive at night n not be scared to get pulled over
Old May 15, 2011 | 03:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: BRAKE LIGHTS WONT STAY ON!!! HELP!!
You have to remove some interior plastic panels to get to the nuts that hold them in. See those big plastic screws that hold them on? First take off the passenger side one that hides the spare tire and then you can take off the back piece. 5 nuts on each one. The ones up in the corners are hardest too see. May have to go through the glove box on the driver side to get that one. Make sure all bulbs are good while you're in there
Old May 15, 2011 | 04:31 PM
Car: 1983 Camaro
Engine: 2.8L V6
ok so i was able to take off that big plastic case that protects the trunk lock but the driver side plastic is attached to the strut...do i have to take the strut off? or am i looking at the wrong spot? ill post a pic if necessary
Old May 15, 2011 | 05:37 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
No need to take that side off. Can you see the black plastic nuts that you unscrew to take the tail lights out? Unscrew them and carefully pull out the tail lights and check what you need to. Reverse for installation
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
