OMG. Radiator fan wiring problems. PLEASE HELP!!!!!!!!!!!
Old May 16, 2011 | 08:50 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Since I got my '86 Trans Am, I've had problems with my radiator fan. It has been jimmy rigged so much. People have ran wires directly into the fusebox wrapped around the fuse itself. Then taped the wires, and I had to use a switch to turn it on and off. At one point it was wrapped around the battery terminal itself to power it.
Today, the fuses burned out again, wires caught on fire, and the switch blew out. It is a real mess. So basically, it needs to be done from scratch.
Can anyone tell me the correct way how to rewire the fan? Does anyone have any diagrams that make sense? I don't mind having to use a switch if I have to. Any help is much appreciated.
Old May 16, 2011 | 11:22 PM
Firebird@42's Avatar
Car: 1983 Trans Am
Re: OMG. Radiator fan wiring problems. PLEASE HELP!!!!!!!!!!!
The easiest way imho is to just buy a thermal fan switch. You can get them at most, if not all auto parts stores, and online. They come with directions and are easy to install for the most part.
Regards
Old May 17, 2011 | 12:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I agree - get an aftermarket seperate fan controller. They range from $40 to over $100, depending on bells & whistles. I run a Flex-a-lite controller, $90 with all the options, and it's been really great - best $ I ever spent. Fully adjustable on/off temps, probes radiator fins for temp sensing, provisions for manual on/off switches, and initializes fan at 65% power so no huge immediate drain on electrical system. I wouldn't trade it for anything.
Old May 17, 2011 | 12:27 PM
Car: 1992 RS
Engine: Carbed 350
But if you need to save the cash, and wire something on your own for now, read my post #2 on this thread: https://www.thirdgen.org/forums/cool...ctric-fan.html
Old May 17, 2011 | 07:13 PM
zwanboy104's Avatar
Car: 1986 Trans Am
Thanks for the advice and tips!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
