Testing fuel pump on 91z
Car: 89 iroc vert-91z-28
Engine: 305 tpi-305 tpi
Transmission: 700r-4-700r-4
Axle/Gears: 3.23 posi-3.73 posi
I think my fuel pump may have took a dump. How do i test the pump by bypassing the relay to see if it is in fact bad? Do i just run a 12v power wire to the "G" terminal on the diagnostic plug? And where is the relay for the pump? Is it the far right relay (drivers side) on the firewall?
thanks, brad
thanks, brad
92camaroJoe
Aug 13, 2015 06:07 AM
