LT1 Wiring
Old May 27, 2011 | 12:26 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
LT1 Wiring
Hey so I'm getting close to finishing my engine swap finally and I just have a few questions about wiring.
Do all of the pink wires that are labelled ignition get routed to the starter eventually? And if so which place on the starter?
And I ended up having to replace the pigtails for the ignition module and coil. Where do they end up?
I also am still planning on lengthening all of the PCM wires so I can mount the computer in the interior.
If anyone is interested on seeing the swap I have a thread at http://www.vancouverfbody.com/forums...ad.php?t=26314
Old May 28, 2011 | 09:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: LT1 Wiring
Originally Posted by caffeine
Do all of the wires that are labelled ignition get routed to the starter eventually?
IGN wires go to the key ;
SWITCHED IGNITION as in live only when IGN is turned ON
Wires marked BATT go to starter (or battery) ; are full time 12V supply ( not switched )
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
