Headlight motor relays dead?
Old May 31, 2011 | 01:46 PM
dallasm's Avatar
My passenger side head light stopped going up the other day, I tested the motor with a 12v battery and it works fine. I have power up to the actuator relay, thinking the relay was the problem I switched the drivers side with the passenger side assuming then the passenger side would go up and the drivers side would not. However, now neither went up. I bought a new relay, placed the drivers side back in place and replaced the old passenger with the new. neither went up. I've tried placing the new one on the drivers side and the old drivers side (that seemed to work) on the passenger side with still no luck. However when I put the old ones back to their original position I still get the drivers side to go up and the passenger side stays down.
I have checked fuses and wires all look fine, like I said the motor works when routed straight to a battery...
The car is a 1984 Trans am stock
Anyone have any suggestions? thank you
Old May 31, 2011 | 02:32 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Headlight motor relays dead?
I thought there was only one relay that powered both headlight motors. When you say the motor works do you mean the light actually goes up and down or the motor works but the light doesn't move? If it's the latter then it's likely the gear in the motor housing or the little circular locking buttons that lock the gear to the output shaft that moves the light up/down.
Old May 31, 2011 | 02:38 PM
dallasm's Avatar
I was reading a another forum saying there are two the Isolation relay right by the firewall and the actuator right next to the light. Its not the gears, when I tested the motor it did move the light up and down properly no grinding noises or anything.
( this is the other forum and used the videos to test my relays https://www.thirdgen.org/forums/elec...headlight.html)
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
