headlights, dash lights, and hatch not working
Car: 1991 CAMARO RS
Engine: 305TBI
Axle/Gears: ONE WHEEL JUNK
my headlights, dash lights, and hatch will not work anymore. i replaced headlight switch and still no go. dome lights also dosent work. i could see how headlights, dash lights, and dome do not work as they all are controlled by the headlight switch but the power hatch not closing is weird to me. any help would be greatly appreciated. what would all those things have in common that would cause them all to stop working. thanks it a 91 camaro rs 305tbi/5spd t-top
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: headlights, dash lights, and hatch not working
Check all your fuses first off then check each component for power and ground
Car: 1991 CAMARO RS
Engine: 305TBI
Checked all fuses under dash. Going to go through wiring next weekend. Basically I'm wondering if there's a power or ground that goes to all things not working. I doubt there all different since they all went out at same time. Thanks for any input or help so far
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
check your fusable links. one time, my air cleaner shorted out my coil & i lost ALL electronics, even radio, it ended up being 2 or 3 fusable links that go on the stud thats on the starter
Car: 1989 IROC Z
i repaired them by just straight wiring it, basically, i cut the wires where the fusable links were than spliced in a new wire and at the end of that i added the correct size "O" shaped connector to fit in the stud, than wrapped alll the wires in electrical tape & attached them to the starter & boom, fixed.
The_Phoenix
Feb 4, 2016 07:10 AM
