1991 Camaro RS Grounding Problem?
Old Jun 16, 2011 | 11:15 AM
jabretsk's Avatar
We replaced everything from the plugs, to the wires, to the distributor cap, rotor, distributor unit, and even the ignition control module.
I have checked for spark coming directly from the ICM and it, also, only sparks intermittently (one hour it might not spark, and an hour later it might).
When it is not sparking, the engine will try to turn over all day long but not catch. And sound strong and charged. Oddly enough, it *sometimes* will initiate a spark from being jump started by another car.
I think its a grounding problem but we're not sure. On top of it, someone had suggested that I might have a problem with the ignition switch, but I can't find anything on where the ignition switch is on the car, never mind how to replace it.
Any suggestions?
Old Jun 16, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1991 Camaro RS Grounding Problem?
Should be 3 major grounds
1) batt neg wire to block
2) groundstrap from rear of pass head to firewall
3) batt neg (small extra wire) to fender
Ignition switch is located on top of the steering column, under the guages. To get to it, you remove the underdash panel, remove the brace that holds underdash panel up, then remove 2 nuts holding steering column up, and let it come down into the floorboard - the wires under it will kinda hold it up. Then you can see the ignition switch.
But the ignition switch won't have anything to do with the ICM not making spark in the distributor - all it does is send 12v+ to the starter solenoid.
jhawkeye
May 25, 2022 06:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
