In need of a electronic guru
Old Jun 22, 2011 | 03:35 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
I’m looking to use a momentary switch as an on off switch. Push it once its turns something on. Push it again turns it off. I only want to use one and don’t want to use a push on push off. If anyone knows anything I would appreciate it.
A circuit diagram would be awesome.
I do have a general knowledge of electronics. If that help cut down explanations and what not.
Old Jun 22, 2011 | 03:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: In need of a electronic guru
http://www.oldradio.com/current/pushon-pushoff.htm
Old Jun 22, 2011 | 08:48 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Clever little circuit! Just handles the relay latching tho - needs a second pole, to control whatever you're switching.
Old Jun 23, 2011 | 05:28 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
now will that ciurcit will work with a momentary switch? ill have to give it a try this weekend maybe. got to get some wisdom pulled friday so maybe during the week.
also i noticed that its noted for 24v. it should be fine with 12v just different component ratings. right?
Old Jun 23, 2011 | 08:15 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That circuit is with a momentary switch.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 30, 2015 07:48 AM
Ranbo108
Sep 9, 2015 12:20 PM
