wiring the power windows
Old Jun 27, 2011 | 10:44 AM
corky09's Avatar
Car: 1988 camaro
Engine: 2.8 v6
Transmission: 5 speed
need help to find where to plug in the power window and locks harness i have a base model camaro wondering how i can wire it up the wiring harness i have is clean and alll plugs are their
Old Jun 27, 2011 | 09:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: wiring the power windows
If you just need power, I'd use the single slot marked IGN in the fuseblock. It accepts any standard 1/4in spade terminal, and provides 12v+ when key is ON. I'd also use an inline fuse between that and the window circuit, I think windows use 30 amp fuses maybe?
The slot I'm referring to will have a small arrow pointing to it, and will have IGN. It looks like a fuse slot, except it's only a single slot, where a fuse needs two slots. There should be 2 of them.
FYI - There are also other slots, marked BAT (12v+ all the time), RADIO (12v+ when key is ON or in ACC position), and LPS (12v+ only when lights are on).
Old Jun 28, 2011 | 10:45 PM
corky09's Avatar
Car: 1988 camaro
Engine: 2.8 v6
ok does the plugs plug into the fuse box then cause the harness has every plug their and its not cut up
Old Jun 29, 2011 | 12:43 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
If the window/lock harness you bought has the plug intact it should plug right into the matching one under the driver's side dash somewhere. It's probably tucked up out of the way. You'll need to add the right size fuse in the slots that should be ready marked. Do you have a manual with circuit diagrams? They'll show the right fuse holders.
Old Jun 29, 2011 | 04:28 PM
corky09's Avatar
Car: 1988 camaro
Engine: 2.8 v6
It's a stock camaro so would the female plugs be in the car ? And I don't have any diagrams can't find any online and I look under the dash can't find any sort of plugs
Old Jun 29, 2011 | 05:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Well first try to get a manual. Chilton not Haynes. Yes the plug should be there. You may need to add fuses. 20amp in the ACC slot, 30amp in the WDO slot and 30amp in the PWR ACC slot. I had to cut a little plastic tab out of the fuse block for one of them. At least this was true for my '91 F'bird. Yours should be about the same. I couldn't tell from my Camaro Haynes manual. That's why I suggested the Chilton one.
Old Jun 29, 2011 | 08:25 PM
Car: 1992 RS
Engine: Carbed 350
wiring diags:
http://www.austinthirdgen.org/index.php?pid=19
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
