Starter relay and VATS module locations?
Old Jun 28, 2011 | 04:21 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
The other day my car wouldn't even crank. It's probably the vats module so I'm curious as to where that is.
Also, I tried to find the starter relay, which I was told is in the driver side kickpanel. I looked and it wasn't there! I didn't even see any trace of wires going to any sort of replay in the area. Any help?
Old Jun 29, 2011 | 12:43 PM
chevydrvr's Avatar
Re: Starter relay and VATS module locations?
Any help?
Old Jun 29, 2011 | 12:55 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
VATS relay is deep inside the middle of the dash. Not at all easy to reach.
Starter relay...I have no idea really, except that I heard the same thing about where it is.
Old Jun 29, 2011 | 01:07 PM
chevydrvr's Avatar
I'll just have to look for it again someday...but I swear I didn't see anything! I saw the wires that go down under the carpet, but that's it.
Old Jun 29, 2011 | 08:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
In alot of cars, the starter enable relay is under the black goo by the hood release handle. The VATS module itself is as mentioned, buried deep under the dash. Therte's nothing "user serviceable" within the VATS module anyway, so no real need to dig it out. But once you find the starter enable relay, you can trace the blck with yellow stripe wire up into the dash to find the actual VATS module.
Easiest fix is to measure the resistence in your key, and buy that resistor ($1), and put it in the VATS wires under tyhe steering column www.thirdgen.org/vats
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
5spdcamaro
Aug 28, 2015 02:12 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
