Wiper Speed Issues
Old Jun 30, 2011 | 12:10 PM
travisgold's Avatar
Car: 1984 Camaro Z28
Wiper Speed Issues
My windshield wipers are driving me insane! the wipers don't work on high they only move 1cm up and down on high the lows work to a point to get them to work i had to adjust the torx screws on the control box under the hood also the mist button shoots no mist at all even though the bottle has tons of wiper fluid in it and the hoses are all connected please help me!!!
Old Jul 5, 2011 | 07:37 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blade Fade
Gain access to the module on the left side of the firewall in the wiper motor assembly.
The connectors you will be disconnecting are the 2 pin connector going to the motor, and the 1 pin connector going to ground.
Insert a voltmeter in line with the 2 pin connector
purple wire and ground for measurement #1.
Insert a voltmeter in line with the 1 pin connector
gray wire and ground for measurement #2.
Keep the wipers switch in the OFF position, and put the ignition key in the ACCY position.
What are the voltage measurements you observe when you have the voltmeter in line with those pins?
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Old Jul 5, 2011 | 01:26 PM
travisgold's Avatar
Re: Wiper Speed Issues
well i don't need to do that right now since i managed to get the wipers working somewhat ill show you a video about what they do http://www.youtube.com/watch?v=3GQsVb4RZbk
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
