Need help!!
Old Jun 30, 2011 | 07:05 PM
lickem's Avatar
Engine: 5.7 TPI
Need help!!
This might be the Rong form for this but if some one know what this code is please help. It popped up on dash dismorn
Old Jun 30, 2011 | 08:58 PM
EagleMark's Avatar
Re: Need help!!
I beleive that is an air bag issue...
Old Jul 11, 2011 | 01:50 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Need help!!
A guy had to replace the horn ring inside a 90 steering column. The yellow wire to the air bag must not have been seated all the way as it worked it's way back out and triggered the "Infl Rest" (Inflatable Restraint) codes. Have you recently taken apart your steering column? Isthe light still on? Haven't seen you in a while. How are you?
Old Jul 11, 2011 | 01:54 AM
Engine: MPFI
Re: Need help!!
Also you can check for loose ground wires. There are 2 of them on the driver side
frame by the engine. Sometimes if they are loose or coroded the
INFL REST will come on.
Old Jul 11, 2011 | 02:00 AM
Engine: MPFI
Re: Need help!!
Ok here is one more idea, guy wrote in another post.
I have a 91 Z28 and it had the 'infl rest' light that stayed on, but it was only a missing 10a fuse for 'SIR'. I put in a 10a fuse and it now blinks and goes off as it should. Just a reminder to try checking the fuse first.
