Third brake light and other ?
Old Jul 1, 2011 | 11:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Trying to return my poor camaro back to stock and I want toget another 3pcspoiler with a third light in it, my oldhatch got shattered and replaced with a 91, how is it wire to get power?? My current hatch doesnt have a little arm to touch the contact plate on my rear panel ive been told thats where the power comes from is that right or is that for the pull down motor? My motor has never worked it got the bolt in the track from the PO
Help would be appreciated on this subject, I wanna see my car like it was when I bought it
TIA
Old Jul 2, 2011 | 12:31 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Third brake light and other ?
That piece is bolted to the underside of the hatch, but you'll require the plastic trim piece to go with it. Also, you'll need to put a hole in your deck lid to pass the wire through. You can come over and check mine anytime.
Old Jul 2, 2011 | 12:39 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Yeah I used to have one, I used my old.trim panel so I know where its gotta go lukes offering me an 85 hatch but if I could find an 89 id like to, how much do you think the yards around here charge for a hatch?
Old Jul 2, 2011 | 01:00 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Yes it is the contact plate, but the rear motor has a plug in that makes the third light work. I have a working motor, but my contact plate was missing. I got one and installed it, then plugged in the small plug to contact plate and it worked great.
Good luck!
Old Jul 2, 2011 | 01:05 AM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
cant you pull the metal piece off the rear glass? if so i have one from an 89 that has the spoiler still on it. small crack easy fix tho lmk and i have a pull down motor, i need to bench test it first but i think it was working as it wasn't screwed in place lmk
Old Jul 2, 2011 | 03:04 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Chris (birdtojag) would know mOre on that than me, he was my go to guy when I was in az, hes out in mesa
Old Jul 2, 2011 | 03:43 PM
Car: 1990 camaro RS
Engine: 305 TBI
Aite well if you find out and do want it lmk
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
