lights and radio questions??
Old Jul 4, 2011 | 11:23 PM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
so i just bought my 85 firebird and was testing all my lights when i realized that none of my pass side rear flasher lights worked, then when i put left signal light it just stayed on?? wtf also the radio doesent work.
I have no idea how to do wiring, any easy fixes??
yes i did replace the flasher module/relay above the convenience center
but it does seem that if i put the one (relay) from the hazards on the turn signals the pass and driver side works but doesent show on the dash while not with the regular one (relay)
thanks all
Old Jul 5, 2011 | 10:22 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Right Is Wrong
With the key in RUN, turn signal stalk in the right turn position, use a test light to probe the dark green wire out of the turn signal switch.
Is there power there?
If not, replace the switch.
If there is power there, make sure it gets in and out of the connector located near the lower right of the steering column.
Then make sure power gets in and out of the connector located at the left rear in the hatch area.
From there it goes to the lamp socket.
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Old Jul 5, 2011 | 07:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Right Is Wrong
Might simply be a bad bulb.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
