Turn Signals really slow when flashing
Car: 1982 Trans AM
Engine: 305 Single Carb
Transmission: Automatic
Ok guys, kinda weird here. When I put on my left turn signal the "FLASHING" on and off sequence is really long. like maybe 5 seconds between intervals. When I turn the RIGHT turn signal on it is a little faster maybe 3 seconds or so but still way to long.
Funny enough the HAZARDS flash just fine.
Any idea what this could be?
thanks everyone.
thanks everyone.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Flash In The Pan
Did you make sure the side marker lamp is also blinking when you checked the front and rear bulbs?
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
Happy Racing!
Car: 1982 Trans AM
Transmission: 765R4
Flash In The Pan
OK due to fact you report all bulbs good and illuminating, a cause could be different brands of bulbs or dirty contacts, both possible problems can be simultaneously addressed by swapping left and right side bulbs and checking for dirty contacts.
After the swap if the right side is slower than the left, the problem is difference in the bulbs.
If the problem persists but they are all blinking adequately bright, you can replace the blinker with an electronic blinker.
The electronic blinker will blink at the same correct speed regardless of any imbalances in your circuit.
Happy Racing!
Happy Racing!
Car: 1982 Trans AM
Re: Flash In The Pan
Happy Racing!
Happy Racing!
Transmission: 765R4
Flash In The Pan
An electronic blinker can be purchased at any well stocked auto parts outlet.
Merely unplug the present blinker then plug in the electronic one.
The turn signal blinker is clipped onto the fuse panel, as delivered from the factory.
However if it has been replaced it might just be hanging in the maze of wires.
It’s round and approximately 1¼” diameter.
The Fuse Panel is located behind a door which is up and to the left of the brake pedal.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Happy Racing!
Car: 1982 Trans AM
Re: Turn Signals really slow when flashing
Thanks for all your help guys..Fxed the problem today. Looks like ll I had to do was replace the Blinker relay under the right side of the steering wheel. Its round in shape and works great. $6.80 CDN cheapest fix on my T/A thus far.
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
