Window switch wiring missing??
Old Jul 11, 2011 | 01:32 AM
gasca_06's Avatar
Car: 1990 Chevy Camaro IROC-Z
Engine: 5.7L (350)
Can anyone please help me figure this out?
I'm trying to get this car put together with everything working, and in the process I found that the wires that go to the window switches in the center console are cut. That is, they are connected to the switches themselves, but then they lead into where the stereo is supposed to go and they are cut there.(has no stereo installed) I can't find the other end of the wires that were cut.
Please help....Need to know where they would be located...
Old Jul 11, 2011 | 02:19 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Window switch wiring missing??
The wires for the power windows are supposed to go under the driver's seat, along the side of the floor, up to the harness behind the dash.
Old Jul 13, 2011 | 12:47 AM
gasca_06's Avatar
Engine: 5.7L (350)
You're right! Thanks for the help by the way. I looked for the wires that you're talking about and yeah they are there. They're connected to the wiring that i mentioned was cut. So I'm guessing that they spliced in that other wiring that is cut to maybe power a stereo. But still...my windows don't work...
Old Jul 13, 2011 | 06:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Those wires aren't supposed to go anywhere near the radio... They run under the seat, down the side of the car, to the harness affixed to the cowl behind the dash, where they run side to side into the doors. Check the fuse panel for 2 silver boxes. One is for the other power accessories, and the other is for the power windows. If the window breaker isn't installed, they won't work. Other than that, there is a junction block behind the driver's side kick panel, looks like a long plastic block with orange wires coming out on one side and pink on the other. The windows should be attached to the pink side.
Old Jul 16, 2011 | 01:06 AM
gasca_06's Avatar
Engine: 5.7L (350)
problem solved! Based on the info, i decided to remove the wiring that i was talking about that im positive was added in. I then connected the remaining wires(color coded) and the windows worked. Thanks a lot!
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
