Interior Lights Went Out
Old Jul 12, 2011 | 05:05 PM
Firebird Fly's Avatar
Car: 88 Formula Firebird, 86 Firebird
Engine: 305 TBI and crate 350
Well basically i got in my car the other day (88 firebird) and found that the dome light and the two lights by the feet in the front that normally shut off when you close the door did not shut off. i had to take the bulbs out so it wouldnt kill the battery..........i have never had this kind of problem before.......ideas?
Old Jul 12, 2011 | 07:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Interior Lights Went Out
Dimmer turned to "on"? Bad door switch maybe?
Old Jul 15, 2011 | 05:41 PM
no i checked the dial for the lights.......... youd think if the door switch was bad the switch on the other door would still shut the lights off..................
Old Jul 15, 2011 | 06:42 PM
Car: 1992 RS
Engine: Carbed 350
NO - say the pass door is closed, and never opens. You open driver door, lights go on, close driver door, lights go off - that is all a function of the driver door switch - has nothing to do with the pass side door.
The door switches make a ground connection when the door is opened, and cut off this ground connection when door is closed (the interior lights have 12v+ to them all the time, and the ground is turned on/off by the door switch). If the wire to the switch is getting grounded anywhere, the lights will remain on until that ground is interrupted.
Old Jul 16, 2011 | 10:28 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Those switches can be adjusted, but you need to remove them to do so. Easy to remove, but the kick panel needs to come out so you can pull the switch out from the back, then the "plunger" screws in or out to adjust as needed. I think someone adjusted my door with a 2X4 to semi-correct sag and the door has a depression in it where it would push the switch, so the switch had to be adjusted out.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
