92 z, won't do anyting??
Old Jul 12, 2011 | 07:09 AM
shine's Avatar
i shut my z off at the store, now it won't do anything-fuses are all good. if fuseable link? how and which wire on the starter relay is it? and can a person move the wire up closer to the battery just in case it happens again. thank you, any knowledge or ideas would be helpful. i'm on o2 -24/7 thanks shine
Old Jul 12, 2011 | 07:11 AM
shine's Avatar
Re: 92 z, won't do anyting??
thank you i forgot to mention it has a305 efi
Old Jul 12, 2011 | 07:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Radio and everything work, just no start? If so, might be a VATS issue.
Or could just be a bad ignition switch, neutral safety switch, or starter enable relay - or a bad wire between the 3 and the starter.
You can take a 3 ft chunk of 10 guage wire, touch one end to the starter where the purple wire connects, and touch the other end to the battery positive post, and see if the starter turns. If it does, then starter and starter solenoid is good. With key in ON position, and you do this, car could start and run - if it does, then it's not a VATS issue, but ignition switch, neutral safety switch, or starter enable relay.
When I refer to ignition switch, I mean the actual switch on top of the steering column under the dash, not the key cylinder. You have to drop the steering column to get to the switch. Good luck!
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
