Repair Bad Alternator?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I have a chromed out 140amp powermaster alternator that I have only put around 5k miles on but the warranty is expired. When I was changing my FPR last week, I accidentally shorted the battery to the alternator casing and I'm pretty sure I damaged it. At 2500rpm, the alternator is only outputting around 12.2v and I'm pretty sure this number should be higher around 14v. At idle, the voltage will drop to around 11.8v. I have stock pullies. Its outputting just enough juice to keep the motor running but it doesn't charge the battery properly. When you try to start the car it almost sounds like its not going to crank then finally fires up. Sometimes you have to jump the car in order for it to start.
Is it possible to take the alternator apart and replace the voltage regulator?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Repair Bad Alternator?
yes it is possible to repair . if i were you i would take to a local repair shop and get it repaired . just my thoughts , good luck .
Car: 1985 Z28
If this is the same type alt that came on the car originally, it probably needs a diode trio. Fairly cheeeeep & eeeeeeeeeezy to replace.
Probably not the regulator. Those almost never go bad.
Car: 1985 Z28
Sorry guys my mistake. It was the 100Amp version. Looks like It's a 12si style:
http://www.jegs.com/i/Powermaster/713/17294/10002/-1
Where would I find the diode cluster for this thing?
EDIT: Looks like I found it. But is a diode trio a diode trio or is there a "Stay away" market for these things?
http://cgi.ebay.com/ebaymotors/7740-...Q5fAccessories
Also, can anyone point me in the direction of a guide to dis/re-assemble this thing?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
