89v6 to 89v8 tpi help needed please
Old Jul 23, 2011 | 05:13 AM
adie's Avatar
Car: Pontiac Firebird
Engine: 2.8 v6
Transmission: auto
Hi all just took out the 2.8 v6 inj out of my 1989 firebird and fitted a 1989 ish 5.0 v8 tpi maf complete with engine loom and ecm.I have no spark or fuel to the cylinders,the engine turns over ok on the starter and the fuel pump primes the system.What should i check,I have a volt meter so can check that just not sure where to check first,really need some help on this one.Has anone done this conversion and should it be a simple plug the new loom in and ecm or are there any differences in the wiring???
Old Jul 23, 2011 | 05:38 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 89v6 to 89v8 tpi help needed please
could be a VATS issue. not sure if the 89 cars had VATS or not. and you have to use the ecm, and wiring from the new motor, the old stuff wont work.
Old Jul 27, 2011 | 03:01 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
pinouts for c100 https://www.thirdgen.org/forums/ltx-...formation.html post #20 not sure if this will help but maybee a start
Old Jul 27, 2011 | 12:00 PM
travis401's Avatar
Car: 91 Camaro RS
the c100 shouldnt change since hes only swapping out motors. thats the connector on the driverside that stays when you pull the old motor out. there will probably be a few wires that run through the wire loom behind the engine over to the other wire loom that connects to the c100. but you can just fish those out and seperate them.
Old Jul 27, 2011 | 12:18 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Since you say you have neither spark nor fuel, I'd look at the ICM, and wiring to and from. Make sure it is getting 12V, and that the harness is plugged in so that the ECM can get the signals it needs.
IROCZ1989
Jan 24, 2016 03:55 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
