Fuel pump relay
Old Jul 25, 2011 | 11:35 AM
joemmcf's Avatar
Fuel pump relay
I have a 88 camaro IROC-Z 5.0L 305 tpi and there is no fuel pressure. We took out the Shrader valve and no fuel. I want to check and see if it is an electrical problem but I am encountering some problems. I can find 5 Relays under the hood. 4 are by the master cylinder, there is 2 oval relays there 1 has 4 wires (2 orange, 1 blue , 1 black) and the other has 5 wires (1 blue, 1 white, 1 orange, 1 red, 1 black) the other 2 are 4 pinj flat relays. The 5th relay is located by the battery. My question is Which relay controls the fuel pump and how do I test it. Thank you.
Old Jul 25, 2011 | 01:50 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Fuel pump relay
first thing to do is check the voltage at the fuel tank. heard the plug corrodes sometimes. if you have voltage it's probably the fuel pump. if not any voltage the relay
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
