dim right headlight on firebird
Old Jul 28, 2011 | 01:40 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
so my headlight is dim and wont pass safety because of it -.- they said it was a wiring issue so i was playing with the ground wire to see it that was it and no change then i took the headlight out and found this...http://imageshack.us/photo/my-images/810/photojzi.jpg/ any ideas anyone?
Old Jul 29, 2011 | 06:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: dim right headlight on firebird
Cut out the bullet connectors and break out the soldering iron to properly put the wires back together. There's probably corrosion in the connectors which are making the light dim. However, that connector you have there doesn't look right altogether, but I have never seen an 84.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Glowsock
Aug 31, 2015 09:01 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
