How to make factory speedo work in 86 ta with no factory computer!!
Old Jul 31, 2011 | 05:31 PM
434Bad_Bird's Avatar
Car: 1986 Trans Am WS6
Engine: Originally 305ci tpi 454sbc now
Transmission: Monster 700r4 SS full manual
Axle/Gears: currie 9" 3.75
Okay heres the deal I dropped a 454ci small block in my 86 ta and completely remover the factory computer. I am running an edelbrock pro flo xt now. Does anyone know how to make the factory speed sensor and speedo work? Will a dakota digital SGI-5 box do it? I sent them an e-mail, but still haven't heard back.. any ideas!!
Old Jul 31, 2011 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: How to make factory speedo work in 86 ta with no factory computer!!
What trans?
Old Jul 31, 2011 | 07:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You don't need the Dakota digital box. If you have a gauge cluster (as opposed to the 2 large gauges and the idiot lights), and haven't adulterated the dash harness, all you need is a yellow buffer box (if you haven't already chucked it, you should have it as it was on the back of the ECM bracket) and the associated pigtails. The wiring comes in through the big connector in the dash from the speed sensor in the tail of the trans and all of the wiring is contained within the dash harness.
Old Jul 31, 2011 | 08:00 PM
okay I know exactly what you are talking about I just unpluged the ecu and removed it the harness was left pretty much untouched.
Old Jul 31, 2011 | 08:03 PM
but i am keeping my factory gauges and all the idiot lights they just no longer light up. will the buffer box still work with the stock speedo? right now my speedo doesnt work.
Old Jul 31, 2011 | 08:05 PM
700r4
Old Jul 31, 2011 | 08:22 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Assuming you have the full gauge cluster, all you need is the yellow box. Plug it back in and check to make sure the speedo still works.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
matthew911
Aug 12, 2015 09:38 AM
beachrodder
Aug 7, 2015 04:27 PM
